MOS - Master of Sound, die neue Reference Serie von Macrom - made in italyDescription:
- Aluminium die-cast basket with high stiffness for rattle free operation.
- Aluminium compound cone on a polymer cellulose base for authentic sound reproduction.
- Special design dust cap for better frequency response.
- High temperature 38.5 mm voice coil former for minimal current loss and maximum excursion.
- Woven-in lead wires for rattle free operation.
- Copper cap on Yoke for impedance linearization and lowering harmonic distortions.
- Stainless steel screw terminal for long-term rust free operation.
- Triple vented magnet system
Technical specifications:
- DC Resistance Rdc [in ohm] 3,6
- Impedance ZN [in ohm ] 5,4 @ 1kHz
- Resonance Frequency fs [in Hz] 50
- Mechanical Qualtiy Factor Qms 3,50
- Electrical Quality Factor Qes 0,50
- Total Quality Factor Qts 0,44
- Equivalent Volume Vas [in dm 3 ] 12,60
- SPL SPL [dB 1W/1m] 88
- Peak Power Rating Pmax [in W] 200
- Nominal Power Rating P [in W] 100
- Frequency Response [in Hz] 50 - 8.000
- Mounting depth[mm] 70mm
WF182BD10 Glass Fiber, 8 Ohm
Gehäuse-Empfehlung 1:
geschlossene Box mit 7,3 Liter
ab 64/40 Hz (-3dB/-8dB)
SW182BD01, 4Ohm
geschlossene Box mit 2,7 Liter
ab 59/37 Hz (-3dB/-8dB)
SW182BD03, 4 Ohm
geschlossene Box mit 5,1 Liter
ab 62/39 Hz (-3dB/-8dB)
W6-1139SIF
geschlossene Box mit 3,7 Liter
ab 67/42 Hz (-3dB/-8dB)
Ich suche TTs die beides können
Max. linear excursion, X max +- 3,5 mm
Bei einer 40Hz Trennung in der Türe muss man nur den Hub gut im Auge behalten.
+- 3,5 mm sind nicht gerade viel :-(
