Passarati
- 14. Aug. 2005
- Andreas
ich habe gerade mit Stephen Mantz kommuniziert.
Es kommt in den nächsten 3 Monaten noch eine 4-Kanal und ein Monoblock
Viele Grüße
Andreas
P.S. Die Leviathan war so im Test:
Manufacturers Rated Power 150 x 6 @ 4 ? , 250 x 6 @ 2 ?, 500 x 3 @ 4 ?
Actual Measured Power@ 1.0% THD+N@ 14.4V Battery 177 x 6 @ 4 ? ,275 x 6 @ 2 ?,532 x 3 @ 4 ?
Actual Measured Power@ 1.0% THD+N@ 12.6V Battery 145 x 6 @ 4 ?, 224 x 6 @ 2 ?, 439 x 3 @ 4 ?
Signal to Noise Ratio referenced to 2V output.
(CEA-2006A) (1 watt @ 4 ohms) -68.1dBA
Signal to Noise Ratio referenced to full 4 ohm output. -90.6dBA
Distortion at rated power 0.017%
Efficiency at 10W/Ch
Maximum Efficiency at full 4 ohm power per ch.
58.6%
70.2%
Idle Current 1.6A
Input Sensitivity 286mV- 9.3V
Maximum Current @ full power 2 ohms per ch. 168A
Frequency Response (-3dB) <10Hz – 34.7kHz
High Pass Crossover 80Hz – 4kHz -24dB/Oct Linkwitz
Low Pass Crossover
And (Ch5&6)
40 – 240Hz -24dB/Oct Linkwitz
Subsonic Filter 11Hz – 48Hz -24dB/Oct
Bass EQ boost None
Stereo Separation (Crosstalk) -61.7dB @ 5kHz
Viele Grüße
Andreas
58.6%
70.2%
Idle Current 1.6A
Low Pass Crossover
And (Ch5&6)
Bass EQ boost None
