So, die TSP habe ich von ETON erhalten. Klasse Service dort.
Nominal impedance Zn 4 Ohm;
DC resistance Re 3,1 Ohm;
Resonance frequency fr 24 Hz
Suspension compliance CMS 0,41 X 10-3 m/N
Mechanical Q factor QMS 3,62
Electrical Q factor QES 0,32
Total Q factor QTS 0,29
Mechanical resistance RMS 4,6 kg/s
Total moving mass (including air mass) MMD 110 g
Effective piston area SD 515 cm2
Voice coil diameter 62 mm
voice coil former Aluminium
Voice Coil length 25 mm
Voice Coil layers 2
Voice Coil inductance Le 1,0 mH
Flux density B 1,0 Tesla
Force factor BL x l 12,8 Tm
Height of the gap 10 mm
Diameter of magnet 168 mm
Height of magnet 24,5 mm
Weight of magnet kg
Mass of speaker 6,4 kg
Characteristic spl 1W1m 90 dB SPL
Rated power 200 W
Equivalent air . VAS 150 dm3
Meinungen sind erwünscht
Welches Gehäuse würdet Ihr vorschlagen?
