dph7500, 910, 913 sind gleich ... der 7500er hat mehr optische Eingänge aber sonst kannst schon das 910er manual lesen ...
Selection of center frequency
Select the center frequency that you want to
compensate from the range of 20Hz to 20kHz.
(1/3 octave step, 31 points)
Selection of Q-curve
Set the sharpness of the Q-curve to one of the
parameters: 1, 3, 5, 7 and 20.
Gain adjustment
Adjust the gain (output level) in the range of -
12dB to +12dB. (1dB step, 25 points)
