audio solutions
- 18. Sep. 2010
- Matthias
Hi!
Hat das schon mal jemand probiert?
Matthias
Matthias
VCam2 app will be installed (or updated) when you launch PowerEventMgr and click the "Launch VCam [Exec]" button. If you intend to use VCam2, you should click this button once, every time you have installed or upgraded the kernel (usbhost installer) via recovery system. Launching VCam2 for the first time will bring up a SuperSU permission dialog. It is necessary to grant VCam2 root permissions.
It is also possible to install VCam2 manually, by opening VCam2.apk from the /sdcard/ folder (say, using a file manager app). Once VCam2 has been installed (or updated), the file /sdcard/VCam2.apk can be deleted.
It is suggested you disable SuperSU toast messages for PowerEventMgr and VCam2. To do so, open SuperSU app, select PowerEventMgr and change the Notifications setting from "Global defaults" to "Disabled". Hit the check mark to store the modified settings. Now do the same for vcam2. And hit the check mark again to store the modified settings.
