Suche Hilfe bei Subwoofer Parameter zwecks Gehäuse
jerry16v
11. Feb. 2010
Würde einer dieser beiden Subwoofer für ein geschlossenes Gehäuse geeignet sein?
<tbody>
[TD="class: xl65, width: 139"][h=6]T/S SPECS[/h] [/TD]
[TD="class: xl65, width: 102"] [h=6]Ev6 8″ D2[/h] [/TD]
[TD="class: xl65, width: 114"] [h=6]Ev6 8″ D4[/h] [/TD]
[TD="class: xl65"] [h=6]RE (Ohms)[/h] [/TD]
[TD="class: xl66"] [h=6]4.02[/h] [/TD]
[TD="class: xl66"] [h=6]5.94[/h] [/TD]
[TD="class: xl65"] [h=6]FS (Hz)[/h] [/TD]
[TD="class: xl66"] [h=6]46.2269[/h] [/TD]
[TD="class: xl66"] [h=6]45.5932[/h] [/TD]
[TD="class: xl65"] [h=6]VAS (L)[/h] [/TD]
[TD="class: xl66"] [h=6]5.8984[/h] [/TD]
[TD="class: xl66"] [h=6]6.4189[/h] [/TD]
[TD="class: xl65"] [h=6]Qes[/h] [/TD]
[TD="class: xl66"] [h=6]0.5617[/h] [/TD]
[TD="class: xl66"] [h=6]0.6170[/h] [/TD]
[TD="class: xl65"] [h=6]Qms[/h] [/TD]
[TD="class: xl66"] [h=6]6.1472[/h] [/TD]
[TD="class: xl66"] [h=6]5.2248[/h] [/TD]
[TD="class: xl65"] [h=6]Qts[/h] [/TD]
[TD="class: xl66"] [h=6]0.5147[/h] [/TD]
[TD="class: xl66"] [h=6]0.5518[/h] [/TD]
[TD="class: xl65"] [h=6]Le (mH)[/h] [/TD]
[TD="class: xl66"] [h=6]3.9549[/h] [/TD]
[TD="class: xl66"] [h=6]5.3356[/h] [/TD]
[TD="class: xl65"] [h=6]BL (NA)[/h] [/TD]
[TD="class: xl66"] [h=6]15.2560[/h] [/TD]
[TD="class: xl66"] [h=6]17.0644[/h] [/TD]
[TD="class: xl65"] [h=6]Mms (Grams)[/h] [/TD]
[TD="class: xl66"] [h=6]111.8455[/h] [/TD]
[TD="class: xl66"] [h=6]105.6520[/h] [/TD]
[TD="class: xl65"] [h=6]Cms (uM/N)[/h] [/TD]
[TD="class: xl66"] [h=6]105.9518[/h] [/TD]
[TD="class: xl66"] [h=6]115.3354[/h] [/TD]
[TD="class: xl65"] [h=6]Sens (dB @ 1w/1m)[/h] [/TD]
[TD="class: xl66"] [h=6]81.91[/h] [/TD]
[TD="class: xl66"] [h=6]81.69[/h][/TD]
</tbody>
<tbody>
[TD="class: xl65, width: 114"][/TD]
[TD="class: xl65"][/TD]
[TD="class: xl66"][/TD]
[TD="class: xl66"]bzw. diese hier:
<tbody>
[TD="class: xl65, width: 120"][h=6]T/S SPECS[/h] [/TD]
[TD="class: xl65, width: 122"] [h=6]SAv3 8″ D2[/h] [/TD]
[TD="class: xl65, width: 114"] [h=6]SAv3 8″ D4[/h] [/TD]
[TD="class: xl66"] [h=6]3.36[/h] [/TD]
[TD="class: xl66"] [h=6]6.0[/h] [/TD]
[TD="class: xl66"] [h=6]38.29[/h] [/TD]
[TD="class: xl66"] [h=6]40.0[/h] [/TD]
[TD="class: xl66"] [h=6]6.88[/h] [/TD]
[TD="class: xl66"] [h=6]7.17[/h] [/TD]
[TD="class: xl66"] [h=6]0.324[/h] [/TD]
[TD="class: xl66"] [h=6]0.392[/h] [/TD]
[TD="class: xl66"] [h=6]6.31[/h] [/TD]
[TD="class: xl66"] [h=6]4.31[/h] [/TD]
[TD="class: xl66"] [h=6]0.309[/h] [/TD]
[TD="class: xl66"] [h=6]0.36[/h] [/TD]
[TD="class: xl66"] [h=6]2.08[/h] [/TD]
[TD="class: xl66"] [h=6]3.32[/h] [/TD]
[TD="class: xl66"] [h=6]18.94[/h] [/TD]
[TD="class: xl66"] [h=6]22.06[/h] [/TD]
[TD="class: xl66"] [h=6]144[/h] [/TD]
[TD="class: xl66"] [h=6]126.6[/h] [/TD]
[TD="class: xl66"] [h=6]120[/h] [/TD]
[TD="class: xl66"] [h=6]125[/h] [/TD]
[TD="class: xl66"] [h=6]82.79[/h] [/TD]
[TD="class: xl66"] [h=6]82.71[/h][/TD]
</tbody>
[/TD]
[TD="class: xl66"]Vielen Dank fürs Drübergucken,
[/TD]
</tbody>
