TeeGee
- 09. Dez. 2019
- TeeGee
Ich habe noch eine Frage, wofür genau ist der Alpine KCE-900E Adapter? unten im Text (leider nur Englisch gefunden) lese ich das man damit ein Navi an Alpine HU anschließen kann, damit der Ton unterbrochen wird,
auf der NVE Seite bei Alpine lese ich das wenn man ein Alpine Navi anschließt "Das NVE-M300P läßt sich nahtlos an die Alpine Digital-Media-Stationen mit Touchscreen-Steuerung Integrieren und nutzt dabei die Navi-Mix Funktion."
Was nun ?
[h=2]Features[/h]Overview: The Alpine KCE-900E Navigation System Interface Box is a navigation voice-guidance interrupt adapter along with an RGB to NTSC composite video adapter. The KCE-900E converts the multi-pin plug on the Alpine's Navigation unit's rear panel, allowing you to send an audio/video signal from the external Alpine Navigation unit to an Alpine in-dash receiver with an audio input and mute wire, and an external monitor with an RGB or composite video connector. The KCE-900E sends the navigation system's voice guidance through your Alpine audio system, and routes the video output to your vehicle's external video screen. This adapter works with the Alpine NVE-N872A, NVE-N852A, or NVE-851A navigation systems.
Connections: The KCE-900E Navigation System Interface Box features the following connections.
Was nun ?
- Navigation Input: 13-Pin Navigation input for connecting the KCE-900E to your compatible Alpine external navigation unit.
- RGB Output: 13-Pin RGB output which connects the KCE-900E to your vehicle's external monitor (via the supplied cable with your navigation unit) to display your Alpine navigation unit's on-screen map.
- Composite Video Output: Composite video output which allows you to connect the KCE-900E to your vehicle's external monitor (via optional composite video cable) to display your Alpine navigation unit's on-screen map.
- Note: There is a switch on the unit which allows the KCE-900E to convert your Alpine navigation's RGB video signal to composite video.
- Guide Output: Mono RCA output which sends the audio signal (text-to-speech) of your external Alpine navigation unit to your Alpine head-unit via an optional RCA cable or RCA-to-mini cable.
- Remote Input: 3.5mm input which connects to the supplied Remote In wire to use an optional IR emitter so you can control your external Alpine navigation unit from its supplied remote control.
- Guide Control Output: Green/white wire which should be connected to the cellular mute wire of your compatible Alpine headunit.
- Display Control Output: Yellow/red wire which connects to your external monitor when available.
